nzbobc
Hi folks,
There's some play in the steering wheel that I can't seem to get rid of. I recently replaced/overhauled all of the steering components including the steering box.
I've adjusted the serrated plate on the bottom of the box so as to adjust the eccentric bush to move the sector on top of the drop arm closer to the worm screw. My serrated plate has two bolt holes. If you recall, the serrated plate has 4 "settings." At one particular setting, the movement is nice and easy but results in play in the steering wheel. If I rotate the plate to the next setting, the components start binding and the wheel takes effort to turn.
I guess I could file out the notches in the serrated plate so that I could set the adjustment between the two settings but I thought I'd ask you guys first.
I've also tried turned the eccentric bush in the opposite direction but I run into the same problem.
