- Mar 5, 2012
- 156
- 32
Hi there, if anyone has done this to their car I would be very grateful for some pictures. I had previously decided not to use the 126 rack in my 500D resto on grounds of originality, but with a 45hp 126 engine, disc brakes etc etc I think I might be dreaming if I think it is still original!
I have the rack from a 126 and have cut out the brackets. Before doing so I took pictures and also a lot of measurements. It looks pretty straightforward, but if anyone has any pics of the brackets mounted to a 500 it would certainly be helpful. Also, very keen to see a photo of the new hole in the bulkhead where the pinion joins the steering column ( to gauge where this hole is relative to the old one) and also the bracket that needs to be made to support the lower column. (I won't be using the 126 upper column, but will be grafting the lower section with the collapsible universal joint onto a standard column).
Thanks Roger
Thanks Roger
