Technical Swap immobiliser and keys?
Scotchgitt
Scotland
I have a 2008 panda with an immobiliser fault and wont start and only have 1 key but car has a pana roof
I also have a 2008 that runs fine and has 2 keys.
Both cars cost me £300 so more of a learning and fun excersise
I would like to keep the pana car so can i swap some black boxes from the working car in order to then have 2 working keys for the non woreing. Obviously the ignition and door and boot handles would need swapped too
Can it be that simple?
As long as they are the same engine type and wiring loom
ECU
Body computer
Dash
Ignition barrel
Door lock
Hatch lock
Passenger airbag switch
And all should work as it did in the other car
Hopefully a proxi will add the functionality of the roof
But you can get a replacement key
When you say it has an immobilizer fault, are you sure, does it turn over, is the Arial okay and so on
Thats excellent thank you so much.
Thats next weekend sorted.
And good point about the passenger airbag switch
Luckily they are both 1242cc and both have close to 60k miles
1 question , why the dash what does it hold the security systems need to access
The milage has to match the ECU otherwise the odometer will not work and constantly flash
You can do a proxi alignment but only if the dash has lower milage, you can only correct upwards
Does the engine turn over
Is the battery light light on
Is the oil light on
Is the engine light on
This car does not have a key or immobiliser error
It's lost connection between the ECU and the the body computer
And would be far easier to to fix the ground issue
Than to swap all the electronics and then it be still the same
Update and thanks for the help
Got the car in my unit now and
When you turn the key the starter does click or turn, dash lights dont dim. But the immobiliser light does go out. So mot an immobiliser fault.
So, i connected a jump leat from the battery -ve to the engine block.
Then when i gurn the key tje atarter clicks then all dash dims
So plugged the booster onto the battery and
Vrooommm it fires up
So off to get a new earth strap and charge the battery and take off the seized alternator
Cracking wee car with the twin sunroof, just like driving my wifes range rover with the twin sunroof
So the project continues…
Also picking up another 60k 2010 panda tomorrow , wonder f the air con still works
These are such great wee cars
But then this morning turns over but not trying to start
Getting fuel ok also ran injector tests and all clicked ok
Taking lead 1 off and starting with an earthed spark plug I get 1 orange spark then nothing
Tested coil packs with multicultural and the spark fine
Swapped crank sensor from my other working car and also cam sensor too
No spark
Can I swap my ecu from my working car to test it?
They are both the same 1.2 engines but different specs
Different keys though
Post 2
BCM
ECU
Ignition barrel
Pointless though
Take a video of the right hand side of the dash as you switch the ignition on then crank the engine
Wasnt sure if i could just swap the ecu to see if it fires up then if it did i could swap everything across bcm keys speedo etc
Here a video
  • IMG_6289.MOV
    64.3 MB
Yeh i have a multi meter
Could it be the alternator? The last thing i touched although it did start up after i refitted it or I can disconnect it and see if it starts
Clean the top of the battery negative and use this for one lead
Clean a spot on the engine valve cover and use this for the other lead
Multimeter on DC volts
If it's not auto ranging around 20V
Crank the engine and measure the volts
Ive put an extra jump lead one as an extra earth and still no start
The lights dont flicker it is tre camera
Lights are either on or off
Is there any function in MES that can dig a bit deaper into this sort of non start? Or is there a howto to logically step through the different systems?
Ive checked fuel - ok
Ive checked spark and there is none but the MES coil pack test works fine
Ive swapped the crank sensor and cam sensor and both ok
So only other thing is timing jumped or ecu?
