Technical Sudden TA+ issues
Nr.Neath & Swansea, Wales
Drive the car about 5 miles in today's hot weather, everything fine. Stopped at Chemist, went in, few mins later came out, hopped in & started the car.
Engine light, s/s unavailable & ! all lit up with a load of warning messages.
Pulled over, turned off & restarted but still the same. Car driving fine though??
Any ideas please?
Sounds weird, it may well be weather related but hard to say as the warning lights are generic.
If the lights are still on though and you're home, you might want to give your breakdown cover people a ring and see if they have an ECU code reader handy. That would be my first port of call, even though the car might seem fine I wouldn't want to risk it.
Our 1.2 Panda did a weird thing yesterday. Turned the ignition on and thought it was a bit quiet; all the lights were on but the fuel pump hadn't primed and the immobiliser light was on, so I didn't bother trying to crank it. Pulled the keys out, switched back on and it was fine and has been since. You never know with these Fiats;)
No I didn't as feared loads of stuff would need resetting.
Would that be the case?
I have CTEK hard wired connections on the Alfa's but just use the clip on type on the 500.
I dont think so but others here might have a better idea, theres not much to reset! Personally it's the first thing I'd try before going to any trouble, might just be in a tizzy and needs a reset. Worth a try:)
I'd probably try 10-15 minutes first; when I did this to sort blue n me the clock needed resetting but the stereo was ok (then lost it's code randomly a few weeks down the line- fortunately the code was in the instruction manual pack thing)
Check the oil level. Sounds stupid but mine had a similar-ish problem and it was down to low oil level. My TA would conk out (with the start/stop unavailable light on) after about 5 mins of driving and then be a right git to restart, it was due a service so I reported it and much to my embarrassment they said it was just low oil and sure enough it hasn't happened again. Hope yours is a similarly easy fix.
Well, been away for two weeks, Mrs SR did the Tesco run this morning without issue. Came to use it this afternoon, started & the bloody warning lights are back. Tried a 10 minute negative disconnect but no cure.
Dealers it is then :(
Hopefully they'll be able to pull a few error codes off it and see what's going on. Could be an electrical problem such as a dodgy earth which is lighting up the dash.
Btw, I see your an AROC man, today in Dublin we have a major annual classic car show on and I'm involved with the Irish AROC section - we have a 4C coming in from the UK for our stand courtesy of Alfa UK so looking forward to seeing that! Someday perhaps!!
That I am. We recently awarded the Irish section an accolade, as you probably know(y)
I know Martin, Myles, Dennis & Noel. Would love to come over at some point:D
Small world! Maybe come over for the Irish trip later in the year? Here's a snap of the 4C from today and one of my own TA with an older cousin!!ImageUploadedByFIAT Forum1404667593.921998.jpgImageUploadedByFIAT Forum1404667638.254205.jpg
I'd love to come over :)
The lights went out this morning!
Typical as car booked in for tomorrow....
I read somewhere that the ECU resets after 6 stop start cycles.
Is this true as it would tally with what happened before we went away.
I take it the fault codes will still be stored though?
Cheers,
Simon
Don't know about the fiat, but my 15 year old puma retained a log of all fault codes for diagnosis (had lots of fun at the beginning of the year with random engine management lights coming on) so I'd say the chances are good.
Cheers,
Simon
Yes I would presume so, worth leaving it in anyway and see what comes out in the wash
