I agree with the points
@steveras57 raises.
The part circled may not come in an after market turbo replacement , it appears to be the waste gate spindle /bushing on the exhaust manifold section.
I have often seen some play there and in bad ones exhaust soot etc. Apart from a loss of exhaust pressure to spin turbo faster, what is the issue you are experiencing.
If you need to replace the whole unit be aware there are a lot of inferior products from the Far East around.
Some time ago I fitted a turbo the customer had supplied, it ran OK to start then after a run it lost all turbo boost on inspection the nut had come off the impeller and dropped into the manifold luckily I was able to retrieve it!
