I would really apreciate some help with this prolem, Stilo is PERFECT 90% of the time... but the other 10% of the time its really irritating. First let me describe the problem and then what i have dont about it (to no avail):
When pulling away particularly in traffic throttle responce is flat and then jumps up to 2000 rmp, sometimes then just dies out but doesnt stall making it kangeroo... it does this fairly regularly!
When reversing the car kangeroos all the time unless i give it loads of revs, again a bit embarassing if there is anyone close by!
I have:
Had the car serviced - oil, filters, plugs, drain and refill coolant.
Cleaned the throttle body (using WD40 and a toothbrush and cleaned up with cloth after)/
Changed the battery today after leaving the ECU unhooked all night.
Cleaned the D4 at the same time as above with electrical contact cleaner.
Like i say otherwise car runs perfectly and some days it will sit at 1500 rpm quite hapilly with little pressure on the throttle but others its 800 or 2000 and nothing in the middle : (
Well i hope someone can give me some more ideas because i think i have exhausted my mechaniacal know how!
Thanks,
Richard.
I have:
Thanks,
Richard.
