Mines the same - car came with one of those tiny aluminium aerials so thought it was that so bought new original type but still the same... Finds one station only.
I had the same issue no stations or intermittent stations.
remove the cover on the passenger door mirror on the left of the mirror / the side nearest the window there are 2 wires remove them and clean up the connections and bingo easy fix. This is the same fix for the air con not working also.
Good luck but it worked for me.
Sorry to have the reaction from you regarding the post about the Fiat 500 radio.
I have not intentionally spammed you as you suggest.
I will cancel my membership later today. Not the best welcome for a new member.
I had the same problem, and I checked the basics first like is the aerial correctly fitted to the back of the headunit. After this I purchased an aerial booster from eBay. It's the type that's like a little black box. I fitted it and then I picked up about 20 new stations. It's been the best £12 spent.
