Guys! I’m losing my mind now…. I run out of ideas
Some time ago I bought Fiat Punto 1.2 8v 2003 pre lift, 56k miles on the clock.
So the issue I’ve got is, car getting micro misfiring ( at least that’s what I think) or shaking for literally second and repeating time to time, it’s also hard to describe…
What I done so far,
Basic service, oil, oil filter, air filter, new spark plugs, new leads, new coils, new thermostat, fresh coolant, just yesterday I replaced rocker cover gasket, also valve clearance been checked and everything up to specs, throttle body been taken off and cleaned up, no air leaks whatsoever. All sensors been checked, all ok. No errors on dashboard, also tried to connect with Delphi but no errors/faults. I’ve also done compression test all in specs. Battery been also charged looks ok, alternator working fine, fuel consumption is in about 43mpg urban+motorway. Idle is stable… don’t know what else I can check
The micro misfiring/shaking is only when the car is running on idle
Temperature is always stable… time to time I’m getting electric steering wheels error on the dashboard but that’s the known issue, restart engine always fix that issue.
There is no problem to start car when cold/hot
Heating it very strong, basically everything is working as should.
Forgot to mention do not have any information about previous service history, don’t know when the timing and water pump been done.
I’m just loosing my mind now…
Any ideas, helpful advice, any suggestions will be very much appreciated!!
The only thing I spot looks like previous owner did not replace the oil to often, he was the very old guy and looking through MOT history was only covering up to 3-4k miles every year…
What I done so far,
