Technical Multiple coil and injector error codes and will not start.
hoopertjam
Hello to all in the Fiat forum. I've attached a print out from MultiECU that specifies errors to all the injectors and coils on all cylinders on my 1.2l 8v petrol my2008 Fiat 500. I'm guessing that there is either a wiring or ECU fault. I do possess both multiECU and a copy of the Fiat 500 examiner CDrom. Any advice about causes or diagnostic procedure would be greatly appreciated.
  • Engine ECM Fault.pdf
I've been continuing my uneducated search through potential causes for the above problem and I've noticed that the same fuse is responsible for both the coils and injectors (F22). So my guess is, the problem us with the wiring within this circuit or maybe the fuse itself. I will check the fuse in the morning. I'm still eager for any diagnostic advice regarding the error codes in the attachment in my previous post.
Thank you for both of those replies. I have found the earth in question underneath the air filter. It looks fine, are there any measureable voltages on that circuit that I could check with a multimeter?
I wonder if the coils and injectors share the same earth and there's a problem with the wiring loom from the ECU?
The Panda Active has a similar issue with a dodgy wire in the loom that causes coil and injector issues.
The wire in question is very near to the connector to the ECU and the fault can be manipulated with the wire.
This one shows the issue and relates to coil, but it has also shown as injector problems as I believe the wire splits with a Y junction further along the loom.
https://www.fiatforum.com/panda/420817-injector-problem-code-p0202-cyl-2-injector-2.html?p=4119624
If you knew which pin on the connector is was, you could run some continuity tests at the coil and injector ends.
In the attached, A030 is the 6 way connector to the coil pack with pin 1 being +12V and pin 6 being ground.
The injectors do not share the same common ground as they are grounded by the ECU individually when activated, but they do work off the same +12V fuse F22; Pin 1 of A030 and Pin 3 of D081.
So failure of both would probably mean tracing the +12V feed through the loom to F22.
Thank you to everyone for the helpful replies. Update to the situation. The car just started this morning. So I've checked, cleaned and lubricated all earths, fuses and relay connections. I've also tried to make the fuse box enclosure in the engine bay more secure as that was particularly loose in every way. Fingers crossed that is the end of it. I shall return here if that is not the case.
