will be between 02-54 miles 40.000-60.000 and the 1.6 and 1.4
so are hg a problem ?
so the hg are solid on these cars then ?
i saw one for sale for £1500 which was a 52 plate stilo with 55000 miles and was clean and looks ok
is that the going rate for a car of this spec
its a 1.6
not sure im getting it atm but thought id join
Head gaskets are not a real problem on the Stilo. The only engine ive seen reported with head gasket failure is the 1.2 16v. I think that's possibly because it has to work pretty hard to shift the Stilo along rather than any weakness in the design like on some of the older Fiat 1.2 8v engines used on Puntos.
Never seen any problems reported on the 1.4 engine, but it joined the range later in the model run (around 2004) so there may not be as many around as there are other engines.
The main issue with the 1.6 engine is coil failure, which affects alot of other cars (Renault & Citroen spring to mind), but it's a very quick job to change. Alot of guys on here carry a spare couple of coils in the glovebox & just change them at the roadside if they fail.
As mentioned, 1.8 & 2.4 engines have variator trouble, but it shouldnt happen if theyve been replaced at the time the cambelt was changed (as they should be).
The JTDs can have the odd sensor failure, but it's rarely reported from what ive seen.
All the other problems (ie ghost warnings & suspension springs) have already been covered.
Most important issue with a Stilo is decent service history & a one or two owner car. There's plenty of one or two owner examples out there so dont settle for anything other than this, or you could end up with a duff example that's spent it's life changing keepers due to problems.
On the whole Stilos are totally fine if theyre looked after.
thanks there lots of imfo so head gasket are fine if engine is checked weekly
will use this as guides if i do go for one
thanks
3 or 5 door
When buying my Stilo I was told the less owners its had the better, as more owners normally means people who have wanted to get rid of the car due to it being fault ridden.
Jon.
Loads of stuff you should be aware of when you buy the car..
Inner tyre ware on the fronts
Outer tyre ware on the rears
Both show the tracking or other problems are happening..
Warning lights on the dash
Air bags
engine management lights
Obviously check the car is good in the body dept and the clutch and gearbox are smooth when you test drive it..also see if it follows the camber in the road to the left
Check there aren't any unusual noises from the engine
And be happy with the deal if you can knock him down further..
whats road noise in these things my current car is noisy and want no noise
