I have one on My coupe, along with a A pillar mounted Gauge, and PRV. My fuellling was checked and was spot on, although I previuosly fitted a new lambda probe. I also fitted 1 grade colder plugs. NGK BKR7EIX to be exact.
The car has now got a far more aggressive power delivery.
Its good to get a health check done on your car first, like compression test, and as above make sure your turbo and clutch are in good order.
Also 2 weeks after fitting mine the original dump valve developed a diaphram leak, so I swapped it for a Baileys item.
