Hi there
I recently bought some leads and downloaded Multiecuscan and have come up with the following codes (I cleared them yesterday but they have reappeared today) -
They only issue I am having with the car is slight hesitation when I press the accelerator which isn't noticeable when driving.
Tim
P0235 - boost pressure sensor (stored)
Boost control solenoid or boost pressure sensor faulty
The fault is not detected now, but it is stored in memory. Clear fault codes, and observe for future appearance of the same fault. Dashboard warning light was not activated for this fault.
P0704 Clutch switch - invalid signal - stored
Clutch pedal switch signal circuit malfunction
The reason for this fault is that ECU has received invalid signal from the sensor. The fault is not detected now, but it is stored in memory. Clear fault codes, and observe for future appearance of the same fault. Dashboard warning light was not activated for this fault.
P1555 - signal low stored
The reason for this fault is that ECU has received very low signal from the sensor. The fault is not detected now, but it is stored in memory. Clear fault codes, and observe for future appearance of the same fault. Dashboard warning light was not activated for this fault.
Tim
