electric73
- Joined
- Dec 19, 2020
- Messages
- 53
- Points
- 61
My car is fiat bravo 1.4 t-get 150hp, 2007. Starting issue appear at almost every cold start. Last thing I do is adding fuel additive to the tank before filling it. Now it has around 35 liters of petrol. The problem still exist. I opened alfaobd to check fra and dtv values(usually uses Torque app for the fuel trims). I deleted self adaptive parameters and after a few minutes of driving, noticed that Dtv factor(or short fuel trim) became 0.515 at idle. And 0.46 at low load. According to the information about adaptations in internet, more than 0.2 means unmetered air leak or not enough fuelb being supplied to the system.
Fra factor, called also multiplicative parameter or long fuel trim, has 3 values - at low load, high load and current load. All of them are showing 1.005 which is good for now. But the long trim needs more driving for a proper reading. My question is can I rely on those readings about Dtv factor? Is it really possible an air leak to cause those high values and be the culprit for the cold start issues?
