Hello fellow Fiat enthusiasts,
I hope this message finds you well. I'm in a bit of a predicament with my beloved Fiat Bravo 2011 1.4 Tjet 120, and I'm seeking some expert advice and guidance from the community.
Recently, I noticed that my battery warning light on the dashboard has been illuminated. Concerned, I decided to investigate the issue further. Using a voltmeter, I measured the voltage across the battery terminals and was shocked to discover that it's reading a staggering 20 volts when the engine is running, instead of the expected 14.2 volts. Even with the ignition turned off, the voltage remains abnormally high at 19 volts.
This abnormal voltage reading has also led to a power steering error, rendering my power steering system non-functional. I'm now faced with the dilemma of whether this is a problem with the alternator or the battery itself.
I've tried to do some research online, but I couldn't find a definitive answer, and I certainly don't want to make the wrong diagnosis and end up with costly repairs that might not even solve the issue.
So, I turn to this knowledgeable community for guidance. Has anyone experienced a similar problem with their Fiat Bravo or any other Fiat model? What could be causing this high voltage reading, and is it related to the battery warning light and power steering issue?
Your expertise and advice would be greatly appreciated. I'm hoping to get my Fiat back to its optimal condition as soon as possible, and your insights will undoubtedly help me in making an informed decision on how to proceed.
Thank you in advance for your assistance.
