Hi, I have ordered a new clutch master cylinder which I intend to fit to my 2007 Panda 169 1.1. The slave cylinder was done a few years back with a sealed system so no bleed nipple. The master cylinder I have ordered seems to have the reservoir with it already filled so I am assuming that it is also sealed and there will be no need to bleed anything? If I do need to bleed the system any thoughts as to how I do that with no bleed nipple?
Also, is there an easy way to get better access to the master cylinder ball joint tucked up behind the clutch pedal? Can barely see it with a mirror let alone get to it. Bad back and neck don't help I guess. Does removing any trim help?
Many thanks
Many thanks
