Hi Tim,
I would definitely not use heat on any suspension or steering components but if you have then you will need to replace the seals..
See if you can find an anvil or solid vice and don't be scared to use the biggest hammer you can find and hit it hard- you should be pretty close to getting it off now! If in doubt i'm sure if you take the steering box into a steering or suspension specialist they should be able to pop it off for you.
Good Luck!
Good Luck!
