re: Abarth - Earth Lead? [AND coil pack]
Okay,
Been in about an hour and been back on the Stilo for most of that - refreshed now
Reminder on state of play when I started: all additional earths to standard that I had put on I have now removed apart from one to the Alternator (as I have this gut feeling about it). Main engine earth had been cleaned as best I could without removing it (liberal dose of electrical contact cleaner) as I can't shift the thing!
Started car - ran perfectly normally - no sign of gremlin
Let car run up to normal temperature - no sign of gremlin
Got hopeful
Checked earthing against various parts of engine/ body as advised in last couple of posts - all read 0.01V or thereabouts with no fluctuation.
Took car on a 10 mile test drive - gremlin re-occurred 4 times when in motion (seemingly mainly when braking or turning right for some reason). Would not occur when idling stationary (normally worst time)
Brought car back to house, bonnet up, left idling 10 mins - no sign of gremlin. Measured Voltage from various bits of the engine and all steady around 13.98v, with occasional drops to 13.5, but 'gremlin' wasn't showing at any point
Something has obviously changed, probably related to the engine earth - all I can think is that the contact cleaner has done some good, but how since it wasn't actually used directly on the contact surfaces?
Short of hanging off the bonnet while the cars in motion I can't now measure whats going on with Voltage when the problem occurs - could not get it to happen when the car was still (complete reversal of previous experience there, normally worst possible period!)
I really do think I have had 2 problems here - an earthing one that seems (maybe temporarily?) sorted or at least improved by something I've done, and a possible further intermittent issue - the 'gremlin'. Maybe Fiat weren't far of the mark in fingering ABS / Body computers?
P.S. Dumb as it sounds, I can't pinpoint the starter from the engine bay (I know, I know!) - I can't identify where a number of the big power leads go to follow them since they disappear under the fuse box on top of the D4 area and everything coming out of there seems to be in plain black wrap - and pretty inaccessible from above, so I'm going to whip the car over the pit & see what I can from underneath, and then maybe take the battery out & check under that fuse box.
Oh, and my lovely G/f has decided the car is actually possessed / cursed and is currently working out where best to sprinkle some holy water from Lourdes to cure it... Think I need to keep her away from the electrics
Just to add - have regained some of my usual good humour now, but this is making me feel & look such a fool. I keep following the good advice given here (which I appreciate immensely!!), I'm darn sure I'm doing it right, and yet results keep seeming to contradict one another on different occasions.
