Abarth - Earth Lead? [AND coil pack]
Okay,
so been getting a weird problem with my stilo abarth last couple of weeks. Kept getting a ticking from the main relay under the dash that co-incided with the fuel guage dropping to zero briefly and the central locking opening & closing. It also adds a mile on to the readout every time it does this. If I'm stationary with the vehicle running it does this multiple times, ending with a crescendo of ABS, ESR etc.. faults that you can only clear by restarting the car. Rarer when actually moving, and the car actually ran fine.
Took to Local garage and they stated faulty instrument cluster, but I wasn't happy with that explanation (and loath to visit either of my local fiat dealers due to bad experiences with both in the past).
So I do the sensible things , checked al the connections I could, including the infamous D4 etc and the problem got less - happening maybe 20-30 times on a 20 mile journey instead of 90-100+.
So tonight I decide to recheck everything (I figure I'm on the right track), and actually decide to take off the earth lead & clean it up (looked a little green at the edges where it joins the body by the suspension turret).
..except when I try to undo the nut the whole bolt sheared off in my hand - cue waiving about of the loose end with half a bolt / nut still attached. Gonne have to drill the remains of the bolt out to get the earth spade connector free.
First question - am I right in deeply suspecting the obviously poor earth connection as likely source of my problems?
My second question is, If I can get the earth spade connector out, can I just rebolt it back to the body in another location - there's a 2nd unused bolt hole about 2 inches down from where the old one connected - I don't fancy having to re-drill the remainder of the bolt (about half?) out from the current hole as well.
After 10 months trouble free motoring thats a set of spark plugs, an ignition coil, and a broken front suspension spring all in the last month.. My patience is wearing a bit thin even though I love the car to bits
Apologies for the long post. Advice / sympathy much appreciated at this point
Okay,
