The crankshaft sensor is to the left of the sump. It is held in by a 10mm bolt. There is a sprocket directly in front of it. Which has the auxiliary belt on it. Make sure you put the sprocket the same way it came off, or the crankshaft sensor will not recognise the pick up and will not start the car.
