Is there a fix for this? Or is it something we have to live with?
Owen.
Is there a fix for this? Or is it something we have to live with? Owen.
Seths problem may be different. Maybe a cable or something is vibrating in the chassis. This should be investigated as it is an easy fix. Seth, you should try giving it a good punch in the area you hear the vibration to see if it at goes away at least for the time you punch it. If it doesn't chances are it's the gearbox mount.
Hi all and thnx for the replys, i have discovered today that mine gos away when warm to
Im thinking its the gear box mount tbh and when its not as cold out side im gona see if i can see any wear on it
The cure to the cold-only glove-box rattle is a new improved Fiat engine mount. I read it here, did it, fixed it 100%
out of intrest how much was it?, ive got to do my clutch shorly and thinking of thowing a new mount in just because its off (and hopefully save any future work)
cheers
roy
yes i can, but i want a VIN from a multijet, where the mount was improved from the start.can't you get the VIN from your own stilo? it's not the kind of thing to publish on an open forum
