p0689109
Member
I have a 2006 1.2 and have a problem with the clock and also the instrument electrics. If not used regularly when I come to switch on the display is correct. After I go to the start position the engine starts no problem but the electrics on the panel seems to die and then recovers. It is as if the electric feed to the cluster has died and then reswitches on. Of course this means that the clock has to be reset with the silly buttons that need to be held until the time is set. The dealer mentioned that it could/would be the battery but I have a load test battery tester and a multi meter that shows the battery and charging system are all OK. The engine starts first turn every time even after a few days or more no problem. I was thinking a relay or even bad contacts on the ignition switch. I have not got a Haynes so cannot work out the circuit. If the car is used regularly it seems to be ok. I am just about to sell the car to a relative and would like to fix this irritating fault if I can.
