LeoJensen
Hi all
I have had a buzzing sound from right side of the engine for quite some time.
It then started to be a lot more noisy after start-up for maybe 30 seconds, so I decided to change cambelt/waterpump/belt tightening device yesterday, as I didn't fancy failure in that department while the wife was using the car...
The operation went well, but didn't cure the sound...
I did spin the alternator while the belt was of, and it didn't feel as smooth as I think it should be. Belt has been changed recently.
The cure is probably new bearings. Is it possible to dismantle the alternator and change them ?
I could of cause buy a new/rebuild alternator, but it seems there are quite many models at quite different prices. Can you help me to find the right model ? Or will any model fit, as long as I choose the 75A forA/C (or is it 90A...?)
It seems to be impossible to see any details on the alternator w/o removing it, the A/C compressor covers it quite effectively...
VIN: ZFA16900000429368. Produced in May 2005. 1.2 with A/C.
