After 6500 miles, the oil on our 8 month old 1.2 Panda was just falling to the halfway point on the dipstick, and rather than just topping up, I thought I'd treat it to an oil change.
The procedure, capacities & parts are identical to the 1.2 500 & so the guide I wrote last week can be used as is:
https://www.fiatforum.com/500/269353-changing-oil-1-2-petrol-500-a.html
Note that although the handbook gives the capacity of the engine + filter as 2.8l, it took the full 2.9l to bring it up to the max mark on the dipstick. (The 1.2 500 documentation gives the capacity as both 2.8l & 2.9l, depending on where you look!).
I drained about 2.6l from the engine + filter, giving an approximate oil consumption of 300ml for the first 6500 miles - I'm happy enough with that.
