I've got a misfire that only seems to be under full throttle, and only on one cylinder (2nd from right)
Any help?
Any help?
Hi Boxer.Hi bludvl
I have what seems like a similar problem to your misfire.
Car idles and revs fine up to 4k and then it's like a rev limiter kicks in - lumpy and "misses" under load.
So far I've changed the following - all to no avail:
Carb (from another car which was running fine when stripped)
Leads (from same car as above)
Points (new)
Dizzy cap (new)
Rotor arm (new)
Plugs (new)
Condensor (not new but the Factors didn't have one)
What exactly did you tighten?
DjPatD said:What he said previously is right. My clutch on my fiat was working perfectly fine until it got stuck in third gear. i tried everything possible, but when i checked out the gear box, the gears were rusted probably from sitting for a while. after some sanding down and tons a grease and oil, it couldnt shift any better.
Hi Boxer.
It was the two mixture screws inbetween the Carby throats, but if you have replaced the carby, then it isn't likely to be the same problem. I can get photos for you if that will help you.
Cheers,
Mike
Thanks for this Mike
Seems the only thing I haven't changed is the dizzy - I'll probably try that and see how it goes.
After that I'm at a bit of a loss.
Davy
