mrichards0
Ok, not sure if I'm approaching this the right way, so any suggestions from people who have removed an engine from an X1/9 would be appreciated. I've snapped more studs off on this 81 X1/9 than any car I've ever worked on, it's a royal pain. There was a stud broken on the exaust manafold, so in the process of removing the manafold, I broke another stud in the head. I tried to drill and tap it, but there wasn't enough clearance (even with the firewall removed to the trunk) and I broke a titanium drill bit off in the block. In frustration, I'm pulling the engine and going to tear it down and send the head to the machine shop to fix my mess. This is where I need help, I had a friend in high school that had an X1/9 and he was constantly dropping the engine by parking under a tree, putting blocks under the engine, removing the engine mounts and using a wench to lift the back of the car up high enough to get the engine out. I have no idea where he attached the cable and I can't imagine the bumper can support that much weight, if that's where he attached it. I'm not planning on using the tree method, but if anyone has ever removed the engine, what is the best (safest) way to accomplish this? I have the following tools: 2 Jack stands that will extend to the height of the engine, a 2 1/2 ton engine hoist, 2 floor jacks (that don't extend as high as the jack stands) and an engine stand waiting to hold an engine. I already had an eye opening experience using wood blocks on top of the jack to get it high enough to get the gas tank out and the jack fell, but luckily I had the jack stands under the car. It still hit the stands hard and scared the crap out of me. Anyway, does anyone have any suggestions for removing the engine?
