Anyone know where I can get a new set? Or can they be re-shaped and reused?
I recently had my front discs & pads replaced by Kwik-Fit (I know, I know , but I didn't have time to do it myself and the MOT was looming!)... Brakes were done fine, although parts were exorbitant, and the car got through the MOT a couple of weeks later.
Recently though, I've noticed a continuous rhythmic knocking/tapping noise from the front-right wheel, which stops whenever I start to press the brake pedal. The knocking only occurs when driving, and then only above 35-40mph. Having looked around on the forum, when the same problem was encountered before, the recommendation was replacement anti-rattle clips -- Mr Kwik-Fit said the same when I took the car back to have it checked on warranty.
So, anyone actually know where new pins/clips might be available? shop4parts and ebay don't seem to have anything; I could probably get some from FIAT but is there somewhere else, or indeed can the old ones just be opened out a little to make them fit better?
I've also started noticing a squeak from the brake pedal around 0-20% travel..... I don't imagine it's related, but what could it be/what can I do to stop it?
Cheers folks
Cheers folks
