im Axle Specialists
Old 19-03-2004   #1
tipo DGT + uno turbo i.e. possible????
Ok ive gone out and bought a 1990 Fiat tipo 1.6 DGT (the one with the knightrider style digital dash), and I plan to rip out the engine here and replace it with the engine and gearbox from my much quicker but rusted away (and sadly pratically unrepairable) 1991 Fiat uno turbo i.e. (non cat) but im finding info on this very scarce.
is it possible? do the driveshafts fit? does the engine fit? exhaust? can you give me any info on this, or has anyone else attempted something this brave/stupid (delete as appropriate)
cheers.
ShaunBurford is offline Reply With Quote Quote
Old 20-03-2004   #2
Trader Rating: 1
It shouldn't be to difficult, as the 1.4 tipo was just the same 1373cc (1.4) ie engine fitted to the late 1.4 Uno's. Since the turbo motor was based upon this it should fit into place relatively easily, although good luck with the driveshafts. I have no idea there.
Matt Endean
SuperUno is offline Reply With Quote Quote
Old 20-03-2004   #3
Chris
Trader Rating: 2
Bushboy has donated!
dont expect it to be as quick as the uno was tho.. a tipo is quite a bit bigger and heavier.
I Have A Cinq Sporting...
...Click Here To Look At It
Bushboy is offline Reply With Quote Quote
Old 20-03-2004   #4
Go on the Fiats!
Steven's Avatar
Trader Rating: 8
Steven has donated!
I agree with bushboy, would it be worth the time, effort and hassle?
<h5>Click here for pictures of my Uno
Click here for pictures of my Brava
Steven is offline Reply With Quote Quote
Old 20-03-2004   #5
yeah the engine should fit mate. just use the tipo gearbox and drive shafts :) pretty straight forward if u ask me but i'd just reshell ur uno turbo ;)
u got any pics of ur uno?
Dunc
Standing 1/4 mile at Santa Pod - 14.63 @ 94.57mph
Dunc Maclean is offline Reply With Quote Quote
Old 20-03-2004   #6
yeah, i know, the tipo wont be as potent, but the tipo is mint and only cost 100 some old mans car, garaged all its life and done about 50k with a full fiat service history. friend of the family arrangement. it is only a motorway car for me anyhow, to commute to work in. besides how underrated a car would it be? it would be written off by everyone as the try and overtake, and although not nearly as quick as a uno, would certainly hold its own. i like the idea of driving something different.
i know have serious doubts about the dash now though. the digital dash doesn't seem to have a convential speedo, but some sort of electrical device mounted in the gearbox (i could be wrong)
thanks for the tips on the driveshafts... sounds like it might be simpler than i originally thought.
Old 20-03-2004   #7
Go on the Fiats!
Steven's Avatar
Trader Rating: 8
Steven has donated!
Well it would certainly be different, thats for sure. :p
Go for it, and let us know how you get on.
www.forzafiat.com
There is a very fine line between hobby and mental illness.
Old 21-03-2004   #8
the digital dash wouldn't have a cable, just a sensor in the gearbox, i think all newer cars have these since digital mileage clocks came in.
incidentally mine doesn't work
Met Cognac 99 Brava 100 HSX, what do you want? cupholders? open door warning light? grow up!
mad_colm is offline Reply With Quote Quote
Old 21-03-2004   #9
Bulgaria
You must change gearbox, get from Uno Turbo, because the standart gearbox from Tipo 1.6 will die. Through off the seats and noise killer...
Fiat Uno Turbo MK1 1.3Turbo
Abarth wheels, MOMO shift knob, Forge atmo dump valve, BMC air filter
kpematop is offline Reply With Quote Quote
Old 21-03-2004   #10
ok so i need the uno turbo gearbox to handle the extra power, but the dash will only work with the tipo gearbox. can i remove the sensor from the tipo gearbox and transfer it over in place of a speedo cable to the uno box.
my original plan was to remove my working uno engine complete with gearbox, clutch, all ancillerys etc. including starter motor and alternator, belts etc. complete and untouched. dont really want to split the gearbox if i dont have to. the uno box is better anyhow. seems geared better.
Old 08-07-2004   #11
Chas Uno has donated!
Air Dodge Champion, Asteroids2000 Champion, Frogger Champion
I know this is an old post, but I thought I could add a bit of info for anyone else who may be considering dropping a Uno Turbo engine into a Tipo.
First of all, it should be a fairly simple swap dropping in the Uno Turbo engine in place of a Tipo unit. The 1.4 Tipo engine is the same as the 1.4 Uno engine, and this is also the same basic engine that the Turbo engine is based on. I'm not 100% sure, but I also think that the 1.6 Tipo engine is the same basic block as the 1.4/ 1.3/ 1.1 (non FIRE) engines as well.
However, the 2.0 16 valve Tipo version has an entirely different engine so wouldn't make a very base for a turbo swap, even though it would already have uprated suspension and brakes etc.
Gearboxes:
Probably best to use the Tipo gearbox, and later Uno's (turbos included) used a Tipo based gearbox anyway. Seeing as yours is a 1.6 it is designed to handle extra torque, so as long as you aren't too wild with the throttle it should cope fine with the Turbo 1.4. You may find the gear ratios aren't perfect, but a check in the Haynes manual should show you the ratios of both the Tipo 1.6 and also the Uno Turbo boxes. They probably won't be that different, though the Tipo may have a higher final drive ratio.
Another good reason to use the Tipo 'box is that you know there won't be any problems with gearchange linkages or driveshafts. Also, it will allow you to keep the electronic sender wired to your digital dashboard/ speedometer, though I see no reason why this can't be swapped from the Tipo 'box to a Uno 'box.
The turbo driveshafts differ from standard Uno driveshafts on the drivers side. Here a two piece drive shaft is used in an effort to combat torque steer. All other models used a single piece shaft. On the Tipo I don't know if a two piece draft shaft was used, but there doesn't seem to be any reason for not using the standard Tipo shafts. You might just have to put up with a bit of torque steer but hey, you can't have everything!
Alternatively, look up the driveshafts fitted to a 2.0 16 valve model. This engine pushes out nearly 150bhp, so maybe you could use the driveshafts from this model? They would be more than capable of handling the power from a 1.4 turbo.
Another area needing looking at is the brakes. The turbo uses discs all round with ventilated at the front. It might be possible to swap the fronts over, but I'm not sure about the backs. Saying that though, disc brakes at the back are not that necessary, seeing as even basic drum braked Uno's had a brake proportioning valve to stop the rears from locking! You'll probably find the Tipo has a load proportioning valve too for the rear brakes.
The exhaust shouldn't be too difficult to solve seeing as most of the turbo stuff is contained within the down pipe area. You may find the turbo downpipe will hook up to the rest of the Tipo exhaust. The only problem might be that the Tipo exhaust won't work well with a turbo application.
The biggest problem is going to be hooking up all the electrics, sensors, turbo engine wiring loom and ECU's. Somehow you will have to incoporate this into the Tipo's wiring loom. It's possible, but might need some planning and an auto electrician to make sure that everything is connected as it should be. Also bear in mind that you will need things like intercoolers, oil coolers, electric fuel pumps and regulators incorporated into the Tipo's body shell.
There seems no reason why all this can't be done to make a Tipo Turbo, BUT, I would have to ask if it is worth it? The basic engine swap should present no real problems, but incorporating all the additional turbo ancilleries and electrics might well be one big headache. You will also have the problem of insurance, as the car will be seen as heavily 'modified' and not a standard car. This could well send the insurance premium through the roof.
Seeing as some very nice Uno's are still around for just a few hundred pounds, I would be more tempted to buy one of these and effectively 'reshell' your rusted turbo. That way you can swap everything over and it should all fit with no problems. The basic Uno bodyshell is pretty much the same as the turbo!
If you did re-shell you would then have to re-register the log book as a turbo, but for all intents and purposes the car will be a standard Uno turbo after that so it shouldn't affect the insurance. Of course, there is also nothing to stop you from swapping over the chassis plates and using the original number plates from the rusted Uno, only that is a bit naughty! If you do this make sure you send the log book off and register the new colour to avoid any confusion from the boys in blue. Also remember that some of the chassis details are actually stamped onto the offside suspension turret, and that isn't easy to change. Still, with an angle grinder and a bit of filler and paint who's to know if it was ever there? Not that I condone doing this kind of practice (ahem!)
Remember that all cars have their details on a central database. So if you have simply reshelled into another Uno without changing the details, then you are stopped by the police and they do a chassis number check you might have to explain why your Turbo is actually registered as a 60S!
Even though your Tipo is mint, I'd be more tempted to sell if for more than you paid, then use that money to hunt down a good Uno with a sound body to re-shell your rusted Turbo. At the end of the day it would make life much easier!
Chas Uno is offline Reply With Quote Quote
(T) Tipo 1.6DGT + uno turbo i.e. possible??? ShaunBurford Tipo (Classic) 2 10-06-2004 02:39
(T) Stikkin a Uno Turbo 1300 into a Tipo setup ChasesDragons Tipo (Classic) 0 23-08-2003 02:47
(G) Tipo Turbo Deisel Prob ?? didgey101 Tipo (Classic) 1 08-04-2003 20:12
(T) tipo 1.9 turbo diesel rear brakes cheeto Tipo (Classic) 1 07-04-2003 20:47
Tipo (Classic) Turbo Tipo (part 2) Tipo16v Members Motors 11 26-02-2003 23:29
