Hi!!!
You remember some (very bad) of youth!
My mother owned a Volvo 343, 1.4 Renault engine, 1977 version. This car was comfortable at all, very pleasant drive, but it was the car which gave the biggest lot of trouble I knew. The rubber automatic transmission rubber belts showed very unreliable, lasting not more than 40,000 km. Moreover, the fuel consumption was terrific, when I drove her car, I was frequently looking under petrol tank to check that it was not punctured, the consumtion being in the worst cases more than 15 litre/100km. Horrific too! At this time, I owned a SIMCA 1501, useful to tow the Volvo!
I owned some English cars, a love thought for a BL Princess 2200 HLS, She exploded engine while towing a car recovery trailer, when I kept a garage, I was specialized in Triumph MG's and other old English sports cars.
And finally, I discovered the FIAT Uno Selecta. No lot of troubles. I replaced exhaust (may be considerred as routine maintenance), the front shock absorbers, advantageously replaced by Koni's (French manufacturer who furnishes a wide range of devices for HST (TGV) or earthquake safe buildings. The water pump needed replacement, and a lower suspension arm. Lastly, I need to replace a corroded wheel rim, causing a slow tyre deflation. Otherwise, no more problems.
I add at each oil drain a really "magic potion" called Mecacyl. This is under a form of a 100 cc bottle containing a blue coloured fluid, to be added to oil, but the oil drain needs only to be done every 10,000 km. Naturally, the oil filter is replaced. The first time I poured the "magic potion", the car emitted a very impressive cloud of smoke from exhaust, as like when the Bismarck attempted to escape from RAF attacks!. A biker who followed my car said me "Stop, you have blown your head gasket" I answered "Don't worry, the engine is cleaning". And now, the engine runs surprisingly smooth, even at 165,000 km.
Finally I really appreciate the handling of the automatic transmission, not being jerky unless in case of wrong idle adjustment
Unfortunately, it's very difficult to obtain technical information upon repair and adjustment about the CVT automatic transmission fitted to Uno and Punto Selecta.
Best regards
Originally posted by dave
CVT constanly varabile transmission. modern vershions have an electric clutch and metal belts on pulleys inside the gearbox,(ecvt)
the old volvo340 and daff's had rubber belts that always snapped and a normal clutch witch would burnout,
Please do not Email or PM me asking for support. Post on the forums instead. Your reply may help someone else. Thank you
