on the back of the brake pads there are 1 small pin at the bottom, all of them has this, my question, if I put the pads in place the pin slides into one of the four slots on the caliper piston, what is bothering me is that as your brake pads wear the piston uses a turning motion to adjust itself. am I right or wrong. so then with the pins in it won't be able to turn out as pads wear. please help me if i'm wrong. see pics
