I've got a weird problem with my 1996 Uno Fire 1100. I've recently changed the thermostat and temperature sensor which were both inoperative. My problem now is that when the engine is cold I get a misfire at very low throttle opening and the engine sometimes stalls. It will restart immediately with no other ill effects. This symptom continues until the temperature gauge rises to, maybe, halfway between cold and normal. After this the car runs perfectly with no other issues. I have changed the distributor module and disabled the anti stall solenoid all to no effect. This never happened before I changed the temperature sensor so I do suspect this although I'm not sure how this could affect the ignition. I do wonder if there are not different temperature sensors for different models of UNO. I will appreciate any advice or help from anybody who may have had a similar experience.
