C Cypress New member Joined Dec 2, 2014 Messages 22 Points 11 May 22, 2015 #1 Hi What is the correct, ideal flywheel timing marks for Uno Mia? 5 deg, 10 or 15 deg?? Mine feels weak, slow at 0 deg. Thanks
johorridoh Member Written a guide Joined Oct 30, 2010 Messages 261 Points 61 Location Duesseldorf May 23, 2015 #2 I don´t know. But you can´t change ignition timing on a car with ECU
OP OP C Cypress New member Joined Dec 2, 2014 Messages 22 Points 11 May 30, 2015 #3 I mean the flywheel mark
UnoMia Member Joined Mar 16, 2007 Messages 141 Points 131 Location Durban Jun 3, 2015 #4 Hi, The correct timing on an 1100 Mia is 3 degrees with the vacuum advance disconnected and plugged. Hope this helps.
