brandtvdmerwe
I am in the process of fixing my 1997 Uno 999 FIRE. About 2 months ago I drove into a concrete pillar in the work car park, damaging the left front indicator, body panel, and causing a road-speed related vibration in the drive train. I did a very poor panel-beating job on the left front body part, just so it keeps the indicator and headlight in place.
I use the car to travel from Pietermaritzburg to Durban and back most week days for work (165 km round trip). I am driving my wife's 2005 Citroën Xsara Picasso 2.0 HDi now, but I feel more comfortable in the Uno in the city.
Last week I decided it was time and started the process of fixing the Uno so I can drive it again. I initially thought it will be necessary to remove the gearbox from the start, but after some deliberation decided to start with the drive shafts.
It took some time to find information on my Uno's drive shaft layout. It is "dry", being a cup with tripode in grease, separate from the gearbox oil. I eventually found some information on the forum, after which I joined.
The left hand drive shaft's tripode elements were loose and it had lost some of the pin bearings. I removed it and it has been completely refurbished with new boots.
The right hand drive shaft was fine but had almost no grease in the boot. The outer CV joint has been repacked and has a new boot on. The inner CV joint will be completed tomorrow by the shop's people because I could not remove the cup from the gearbox, no matter what I tried. I want to get a tool made for future that will look like a tie rod end splitter but with a wider Y neck to fit the cup. Has anyone seen a tool for this?
The shop gave me grease and I tried to fit the boot to the cup, but was unsuccessful. Does anyone know this technique?
Tomorrow I will find out if the left drive shaft was the only problem or not.
