The pipe to be changed can be seen at 0.16 into this video. It is the 'corrugated' pipe adjacent to the alternator
just had my moho booked in for thursday for the recall EGR pipe being told it could take up to 5 hours depending what they find
Had my van in for a service at 30,000kms last week
Iv mentioned the problems that I have with it from the 1st day of ownership, flat spots, power surges and bad mpg
They drove it and couldn't see anything wrong and done a flash update on the software
One thing they did find was that 2 of the injectors were giving to much diesel so I have it booked in next Monday for these to be replaced
Hopefully this will solve any of the issues
=rolopolo;4319175
Was informed to Not drive the vehicle and should have been told not to drive it.
Basically if anything else breaks, goes wrong as a result, it may not be Fiat’s problem!!!
Even though they cannot supply the part
T
A friend of mine with a motorhome less than 8 months old has had to leave his at a Fiat Commercial garage as the pipe has split on his and they have said the same - not to drive it anything else breaks etc. They have no idea when the part will be in to carry out the recall work. Fiat Customer Service not any help.
I've had mine (2016 MoHo PVC) into 2 different dealers for the EGR recall.
The first checked it and said it was fine (obviously I've no idea if they looked or not), then told me that actually the chassis number isn't in the recall.
the 2nd dealer, when I asked about the recall, said the same thing.
However - according to the VOSA site (www . dft . gov . uk / vosa / apps / recalls / default . asp]), the recall affects vehicles with chassis numbers between 02A59559 - 02F21177.
My chassis number is 02B1XXXX* - which, as far as I can make out, SHOULD be in the recall! (B comes after A and before F!)
So - who's wrong, VOSA or FIAT?
Obviously it's now too late for me - we're off to Europe for the rest of the year - fingers crossed!
The range of VINs encompasses more vehicles than are subject to the recall as far as I'm aware.
I'm not certain of the reason for this particular recall, but having experience of the industry one possible explanation is that only a specific batch of parts are affected. For example, manufacturers often have a particular part produced by more than one supplier, so that they are not left high and dry if one of the suppliers has a strike, goes out of business etc. It may be that a batch of parts from one supplier only is at fault. With current production methods where parts are individually designated to specific vehicles, labelled as such and arranged to arrive at the production line just in time and in sequence to be fitted to the correct vehicle, Fiat will likely have knowledge of exactly which vehicles are affected. But on notifying DVSA, they have to state the range of VINs that encompasses all the vehicles affected, even though this will include unaffected vehicles within the range.
My E5+ van is not subject to the recall, although its VIN falls within the published range because it was built after E6 production had already commenced due to a factory outage in early 2016. My VIN is 02B4xxxx, so on the face of it built after your E6.
Put your VIN into the Chassis Check box on the following link. It will tell you whether your vehicle is subject of any recalls or not:
