General X250 from centre bumper removal
rolopolo
Established member
Hi guys,
Just a quickie, how easy is it to remove the front centre bumper/grill?
I want to instal some mesh grill behind to stop stones damaging rad & a/c rad
What's the procedure?
Neil
Undo the 4 bolts along the top. There are two screws holding the grill to centre bumper one at each side. you need to be on your knees looking upwards. You can remove the centre bumper as well if you want by removing the two bolts at the bottom.
Sounds straight forward :) (unusual for fiat!)
Sounds and looks easy but doesn't work! I've taken out the 4 bolts at the top which are under the bonnet edge. There are 2 of those funny push in plastic connection thingies under the front which I took out and 2 bolts underneath. Ends up a bit lose at the bottom but still rock solid elsewhere! What am I doing wrong folks?
Copied from another forum - may be of some use..
Once the four screws are removed you pull the panel up and towards you at the same time to disengage the clips down the sides. Then you need a flat screwdriver or wider plastic tool to lift the bottom part out of the bumper. They almost always pop out of the grille and sometimes break but as long as a couple are fit to go back in again the grille will sit securely.
