Have a 2007 2.3 120hp Ducato and found the engine fuse box is shorting across between two relay pins and therefore goosed.
Had a look on flea bay and see lots of apparently identical units but all have a slightly different part number to mine, I assume as the manual suggest only one setup for fuses and relays the units must be swappable. Can anyone confirm if this is the case?
