Technical X250 cab socket upgrade
Techno100
Mine is left hand drive hence pictures reversed
The reason for the change is that 12 volt plugs usually keep coming out of contact over bumps causing loss of power to sat navs/ chargers etc without you realising until it proves inconvenient.
These twist lock sockets prevent this
Pictures a bit out of sequence as I've already fitted the new sockets.
First remove the rubber seat for the ashtray cup holder. Then remove the T25 torqs screw.
The whole switch panel then pulls up on the front edge nearest you and out towards you.
The pair of original connectors have a seperate small +ve wire for illumination of the cigarette lighter socket, this wont be needed so cut off and tape back.
The large yellow +ve requires a blue female 6.3mm spade and the -ve black a red 6.3mm
Optional permanent live :- https://www.fiatforum.com/ducato/357045-x250-cab-12-volt-socket-permanent-live.html
