Technical X230 air conditioning evaporator drain pipe location
Does this help?
I should have mentioned it's a left hooker, this is the passenger side foot well, under the glove box. The black plastic moulding to the right is the bulkhead connection, carrying the two a/c circuit pipes and the drain. You can locate the position of it by looking under the bonnet to see where the a/c pipes go through the bulkhead, the part in the picture is in the corresponding position on the cab side.
Thanks will have a look tomorrow. Mine is a RHD and the AC bulkhead pipes are on the passenger side below glove box, so mirrored image of yours. The hose with the jubilee clips on your picture I assume is the drain hose? I don’t have this on mine. There is no sign of a drain hose outside either. It’s very strange😂. Thanks for your assistance
Yes I believe it is the drain, from memory on the engine side of the bulkhead gasket is a moulded rubber drain pipe going down behind the engine. It's very hard to see on a LHD because it is beneath the manifold, Aircon pipes and battery tray, etc.
