Styling x19 wheels
Styling x19 wheels
Bobbylad
Will standard x19 wheels alloy wheels fit an uno???
Bob
i suspect there are clearance issues, as the various alloy retailers do not show up sizes above 16 for uno wheels. they may be being conservative, but 19 is quite a bit above 16. if you really really want bigger wheels & budget isn't an issue, you could change the suspension and raise the car just for that purpose - but would still need to check the offset / inset clearances - i forget what way they are. also remember that bigger wheels = needs better braking for them (tho going from cast to alloy could-should make them lighter, it depends & i wouldn't know offhand.) and your speed indicator and so forth will change readouts, & there's other things affected too because of the rolling circumference changes.
I used to see a mk1 Uno about with x1/9 alloys fitted, so can't see why they wouldn't!!
Obviously you will need the longer bolts for the alloy wheels, as there wider wheels!! But most Fiat models of the period with alloys, should provide the bolts you need should you not have any.
I'm not sure if spacers are really necessary, but you should be good to go :)
