Technical  x19 indicators
abarthstef
hello, my 1500 x19 is going back on the road after 10 years resting.
the indicator are play up thou. the right hand indicator are ok but when you try and signal left the front and wing indicator light up but don't flash and the rear light does nothing at all, the bould looks fine.
any ideas?
cheers,
stef
Check all the earth connections, also the fuse. I had to clean the fuse connection to get mine to work.
i cleaned the connectors and put and new one on the rear left indicator and it worked! now i'll have a go at cleaning the hazard switch.
cheers
