Standard X1/9 brakes should be sufficient to stop an unmodified car, however because the newest cars are 17 years old the brakes usually suffer from being poorly maintained. It may be worth getting the cylinder seals stripped down and re-conditioned by a friendly mechanic to bring them back to new specification. Also replacing the master cylinder at the same time is worthwhile although this is more than a little tricky due to its location above the steering rack. The rear cylinders in particular have a tendency to rust and seize up and are not a very good design. A solution to this for the rears is to fit Fiat 132 rear callipers (also found on some FSO models), which are easier to maintain. However they do move the brake bias a little to rear, which can be welcome if your car suffers from the front end locking up.
If you want to swap the full set try those from Uno Turbo's however you may need to change the wheels as the callipers wont fit inside most of the X1/9 wheel designs. As for ventilation this makes little difference to performance and really isn't worthwhile unless the car is used for racing / track days.
