Technical Wishbones
Technical Wishbones
500e
Uk
Is the Doblo 57plate wishbone common to any other Fiat want poly bushes not listed before 09.
Have nearly got tyre wear under control :idea: I have been playing with track camber & tyre pressures, the last set of cheap tyres have lasted 50% longer than the last set, think the polys will give me acceptable ware, still not good but better
I can't give a definitive answer but what about having a hunt through ePER to see if you come up trumps with matching part numbers.
