Technical Wiring Reverse/backup light for X250?
mcbcotje
NL
Hello,
Looking for the wire on the fusebox that triggers the Reverse/Backup light. Found all I need (see below, located on Connector-C) but only Reverse is missing. Do not have (found) pinout for the other connectors. Anyone?
Flasher R+L triggersConnect to Connector-C on fusebox pin 18-R, 6-L (pink)
Brake triggerConnect to Connector-C on fusebox pin 31-R, 44-L (green)
Normal light triggerConnect to Connector-C on fusebox pin 8-L, 9-R (yellow/green)
Reverse/Backup trigger??
FogConnector-C pin 26-L, 43-R, only enables for seconds!
Maybe Connector-E, pin 7/8?
Yes, just confirmed these pins get triggered by reversing!
