Technical Wiring problems
a kuenne
Nantwich
Hi I have a 2003 2ltr jtd motorhome I bought a towing dolly yesterday plugedit in to drive home only gone short distance and realised the indicators were not working front or back also hazards not working and both side lights on rear not working need some advise please Allan
Model
Filet ducato 2ltr jtd 2003
Year
2003
Mileage
63000
Allan,
Please confirm whether your 2003 registered vehicle is an x244, or an x230 model. While the x244 was introduced in 2002, due to conversion and sales delays it is quite possible for an x230 to be registered in 2003.
Hi it’s the 244 model
It seems possible that since the towing dolly was "plugged in, it may have overloaded the "Switch Control Panel" which embodies the flash generator, or more simply blown some fuses. As the vehicle rearlight clusters are separately earthed at the rear, a faulty earth would seem to be an unlikely cause.
I am attaching Fiat eLearn diagrams, to which I have added component designations, and my own version of the LH Cab fusebox which is slightly customised, but still mostly applicable.
  • eLearn E2010 Side & Rear Lights.pdf
  • eLearn E2020 Direction Indicators.pdf
  • Fusebox B002 Cab LH.pdf
  • Fiat Wiring Colour Codes.pdf
@a kuenne ,
If you follow this link to 4cardata, you be able to look up diagrams online, but do be aware that some are obscured by oversize script. The advantage is that you can scroll down to each component, click on it, and read wiring details.
