Technical  Wing mirror replacement
Judging by the diagram on ePER, it looks like the inner plastic cover is clipped in at the top and hooked in by a plastic tab at the bottom, so I would try gently levering the top out first then lifting it up off the tab.
Dave.
Hi Dave,
Thanks for advice. Levering gently from the top worked OK. There are 3 star headed machine screws; 2 under the plastic trim and one under the rubber just where the door closes. Getting the screws back in is a little tricky because of access but I used a long star bit with a dob of vaseline on it to hold the screw and presto job done. Managed to get a complete colour coded electric unit from a well known internet auction site for £15 including postage.
Thanks again
Tim
