Window Wipers
Window Wipers
M
McD
My windows wipers have started acting up.
When I put it onto the timed wipe, the wipers are just moving constantly, at the same speed as what would be the first constant wipe.... (if you get what i mean)
Also when I go to stop the wiper they now just stop wherever they are on the windscreen, instead of automatically going to the bottom of the windscreen.
Hope this makes sense?? Cna anyone provide an answer or reason???
most likely problem is the stalks im afraid, bit of a pain in the bum of a job, bu if you get a new set from the scrappers its a fairly cheap job (esp in comparison to cost of new parts!)
Andy
there are just some people that screw you up and dont give a damn, unfortunately i seem to have found that one!!!
It's not definitely the stalks, could be them or the motor. I had similar problems with my wipers but also with my lights shorting the whole elctrics out when I put the main beam on or off. I changed the stalks and it solved the lights problem but not the wipers. I changed the wiper motor and it did the trick.
My suggestion is try the motor first as it's the cheaper and easier job.
Gav
You don't need pants for the victory dance
L
1
756
Tommy K
T
M
1
552
Dark Lurker
M
7K
mick gibbons
M
750
Dark Lurker
C
2
832
K
