Window tints!!! aahhhh!
W
Warren
Don't you just hate them!
just been trying to do mine on my bravo they just won't work! in the end i ended up fluffing it up big time with it all stuck together and was like f*** it for tonite.
anyone know of a spray?? (easier) or some precut ones?
or got a guide/tips on fitting some :)
cheers!
avoid sprays, fukin ****, i tried it, and i cdnt see outa my rear window at all, so had to rub it off, and the only way to rub it off was to spray more on and wipe it quickly while its wet, becuase by sprayin more on, it turns the dry spray back to a liquid so u can rub it off, other wise its really hard to wipe off. plus my car stunk, and what a mess, blotchy, prob can be done, but professionaly, so u may as well have proper film tints.
just ordered some more! gunna try it again :)
this time i got more so i can afford another f*** up :)
anyone got any tips?
ok some quick tips
1. cut the film to the outside shape of the window then heat on the outside with the backing stil attached to get the shape of the glass (dont melt it to the glass lol)
2.wet the inside of the window with soap water from a spray bottle
3.then carefully peal the backing off spraying loads of soapy water on the stickey side now place the film on the inside of the window trim then squeegie the little bubbles and as much of the water out that you can.
its much easier to do if you take the boot lid off the car.
for the soap water mix spray do about 1part soap to 100part water
Had a go at this my self and there is a reason why pro tinters charge well over £100. Cos its a bloody night mare . The worst thing is you doin it your self spending all your time on it then it looking a little dogdy. Im not knocking your ability but it is really best to get it done pro, which area are you in as I know a pro place that does a bravo for around £160 with a life time cover against peeling . Other places charg stupid amounts like over £300 , just get it done pro u wont regret it mate .
would but i can't really afford that :)
i've ordered some more and i'm going ot try again :)
I did my own guide for this but the shortcuts on the PC at work. Wil post for you monday.
L
1
757
Tommy K
T
M
1
553
Dark Lurker
M
7K
mick gibbons
M
C
2
832
K
