who has got 17" lowered by 30+ on standard shocks.?
T
Truffles
as the title states, im just wondering what the ride is like with lowered springs and standard shocks.
any posts would be great. thanx.
I had mine done on my 1.8HLX the ride was pretty good, not as bad as i expected, harder than usual but pretty good overall
But......ive just put KYB gas shocks and lowered my JTD 50mm and the ride has vastly improved, so i would say it is worth changing the shocks aswell as you can get a set of KYB gas shocks for £100 all in and it will be cheaper in the long run, as you will have to have them changed eventually
Lozz
pretty much everyone around here who has 17's (thats about half the forum) has also lowered it 30+ The lowest drop you get is with eibach springs which claim 33mm drop but its more like 30 up front and 20 out back. thats what half of those whove lowered have too.
some crazy folk, like Paul R for example have had everything from 15's on a 30mm drop through to 18's with a 60mm drop. last i heard he had 19's on a HGT and was dropping it on coilovers.
anyway, i digress. standard shocks are fine, so long as they are newish... if like most of us, your car is over 5 years old, is definitely worth changing them when you fit the new springs. your ride and handling will probably already be affected by the old shocks. fitting new ones and lowereing will, i imagine, give you better handling, and the same sorta ride as you have now. the exception being potholes... dodge potholes if you have 17's!
Buzz (formerly LightWarrior)
The champion of the Bravo 1.4
Owner of the Bravo 1.8
http://www.bravo-guide.co.uk/members/59ianalexandria.htm
thanx for the info guys..
iv just fitted new rear shocks, but i can feel that the front onces need doing.
would i be ok getting new KYB shocks for the front, and new lowered spring all around with a 30 (whatever) drop.
im not all that worried about making it better than it is now, but id like to keep the same feel to the car as i have now when i have 17s on it.
does any1 know the link to wear i can buy these KYB shocks.
thanx.
F
7K
F1-ANG
F
E
1K
E
J
527
Jonathan Rigby
J
N
291
Nuno Costa
N
