Very easy to take them out.
Remove the cover first.
There are 3 or 4 allen bolts along the top, two just behind the steering wheel cover (put your steering wheel in the down position to see them), remove the fuse cover and there is 1 screw on inside and at the top.
Once it is all undone, put the cover towards you, unplug the two connectors, then slide out to the right.
There are then 4 screws holding in the dials, all clearly visible.
Pull the dials out towards you and tilt forward, you will see two connectors, unplug them and remove the dials in the same way as the cover.
c/o Daz
