Technical Which MAF?
Hi, I have 2007 Bravo 1.9 150hp with DPF and I need new MAF. I know only Bosch will work correctly, but which one should I get? Offline Eper by VIN search gives me 51782034 as well as all eshop.
But I have installed 55183650 which looks the same, but is almost double the price. Also it is made in 2007 - same as the car, and Polish online eper says it is correct number.
Some compatibility tables says it is compatible only up to 120hp engines.
I also tried to find one for Alfa Romeo with this engine, but every one has another model number (looks the same, costs more)
Is there any way to check which one is correct? Or perhaps both can be used as one is newer model? Or DPF version has different MAP?
