Where To Find Torque Settings - Scudo Van
woodbine66
I'm changing the broken front coil spring on my 2004 Scudo 2.0 JTD, so will have to remove the strut. Where can I find the torque settings that I will need?
The settings I need will be the two 18mm bolts that hold bottom of strut to hub, the two 16mm bolts up inside wing that hold top of strut to inner wing and also the big nut at the top of the strut that holds the strut together.
Any help appreciated.
Try the Scudo service manual located here - https://www.fiatforum.com/downloads.php?do=download&downloadid=312
You'll need to download all of the parts, then extract the contents using WinRAR or similar.
I think the output file is a .iso which will either need to be burned onto a CD or 'mounted' as a virtual CD-ROM drive using software like Daemon Tools.
Thanks for your answer. I asked a question about something else on here a while back, and I remember them giving me advice to use Win -RAR. However, my computer knowledge is basic, and I got in a terrible mess. In the end, I couldn't make it work.
Is there an easier resource where I can find the info? Does anyone have the torque settings handy?
Bring back the days of a well-thumbed Haynes manual.
